Hello Guest it is November 22, 2026, 02:27:32 PM
Author Topic: G21 scale all with 25.4  (Read 8665 times)
« on: June 21, 2014, 05:36:38 AM »
I have problem that if cambam add G21 to code it will cause mach3 to multiply all numbers with 25.4. If I remove that line then all works well and units are millimeters in file and mach3 but if there is G21 row it will multiply all units ~25.4. So it thinks that I have something in inch mode and it will try scale them to millimeters? What I need change that it will understand that all units are in millimeters in first place?
Re: G21 scale all with 25.4
« Reply #1 on: June 21, 2014, 05:53:13 AM »
Config >Select Native Units, and set to mm.
If it was in inches, you'll need to change  your steps/unit in motor tuning and re-adjust your velocity and acceleration.
« Reply #2 on: June 21, 2014, 05:54:29 AM »
No, point is that g-code is in millimeters allready. If I remove that G21 line then all works fine.
« Reply #3 on: June 21, 2014, 06:07:40 AM »
Before you load the code that causes the scaling, look at the upper right of the screen. Is there a G20 or G21 in the status line? If there's a G20, then you're in inch mode. If it says G21 before you load the code, it shouldn't be doing any scaling.
