Hello Guest it is November 22, 2026, 07:41:19 AM
Author Topic: MAXNC-10, HSM, alignment issue  (Read 8415 times)
« on: June 14, 2014, 07:10:21 PM »
Machine 0,0 is at the bottom edge of my hole plate and the right edge of the 1x1x4 bar seen in the second picture.  Orientation of the cut is ok, but the position is off.  Out of ideas and could use a few.  I have not made any cuts with this machine yet, but it is set up IAW a pdf online for this specific machine and everything seems to be acting as it should.
Here is the way the job is set up.  0,0,0 is the center axis and the top of the part.
Here is what the cut preview looks like.  Looks good to me.
Here is the part on the machine.  It's hard to see, but the spindle is lined up with the axis.
Job zero, after hitting regen toolpath:
My machine does not have limit switches.  It is set up IAW the pdf in this thread: http://www.machsupport.com/forum/index.php/topic,11409.0.html
Machine coords, same spot:
Offset tabs, just in case.  Job coords:
And machine coords:
My question is, why is the toolpath to the top left of my g54 zero?  Shouldn't it be center and below?
« Last Edit: June 14, 2014, 07:12:03 PM by desertT1 »
Re: MAXNC-10, HSM, alignment issue
« Reply #1 on: June 14, 2014, 07:29:31 PM »
Let's see if I can post the txt of what the machine is trying to do:
Code: [Select]
(CONE_SLOT)
(CONE_SLOT)
(T3  D=0.054 CR=0. - ZMIN=-0.38 - FLAT END MILL)
G90 G94 G40 G49 G17
G20
G28 G91 Z0.
G90
(2D POCKET1)
M5
M9
T3 M6
S1000 M3
G54
M9
G0 X0.1145 Y-0.8968
G43 Z0.6 H3
Z0.2
G1 Z0.1054 F10.
G18 G3 X0.1093 Z0.1 I-0.0054 K0. F3.3
G1 X-0.1069 Z0.0925
G17 G2 X-0.1217 Y-0.8923 Z0.0919 I0. J0.027
G1 X-0.1591 Y-0.8677 Z0.0903
G2 X-0.1847 Y-0.8201 Z0.0884 I0.0314 J0.0476
X-0.1831 Y-0.8065 Z0.0879 I0.057 J0.
X-0.4089 Y-0.7189 Z0.0794 I0.1831 J0.8065
G1 X-0.4075 Y-0.722 Z0.0793
X-0.1413 Y-0.8974 Z0.0682
X0.253 Z0.0544
Y-0.8968
X-0.1069 Z0.0418
G2 X-0.1217 Y-0.8923 Z0.0412 I0. J0.027
G1 X-0.1591 Y-0.8677 Z0.0397
G2 X-0.1847 Y-0.8201 Z0.0377 I0.0314 J0.0476
X-0.1831 Y-0.8065 Z0.0372 I0.057 J0.
X-0.4089 Y-0.7189 Z0.0287 I0.1831 J0.8065
G1 X-0.4075 Y-0.722 Z0.0286
X-0.1413 Y-0.8974 Z0.0175
X0.253 Z0.0037
Y-0.8968
X-0.1069 Z-0.0089
G2 X-0.1217 Y-0.8923 Z-0.0094 I0. J0.027
G1 X-0.1591 Y-0.8677 Z-0.011
G2 X-0.1847 Y-0.8201 Z-0.0129 I0.0314 J0.0476
X-0.1831 Y-0.8065 Z-0.0134 I0.057 J0.
X-0.4089 Y-0.7189 Z-0.0219 I0.1831 J0.8065
G1 X-0.4075 Y-0.722 Z-0.022
X-0.2171 Y-0.8475 Z-0.03
X-0.1413 Y-0.8974 F10.
X0.253
Y-0.8968
X-0.1069
G2 X-0.1217 Y-0.8923 I0. J0.027
G2 X-0.1847 Y-0.8201 I0.0314 J0.0476
X-0.1831 Y-0.8065 I0.057 J0.
X-0.4089 Y-0.7189 I0.1831 J0.8065
G1 X-0.4075 Y-0.722
X-0.2171 Y-0.8475
X-0.1413 Y-0.8974 Z-0.0332 F3.3
X0.253 Z-0.0469
Y-0.8968 Z-0.047
X-0.1069 Z-0.0595
G2 X-0.1198 Y-0.8935 Z-0.06 I0. J0.027
X-0.1217 Y-0.8923 I0.0129 J0.0237 F10.
G1 X-0.4075 Y-0.722
X-0.2171 Y-0.8475
X-0.1413 Y-0.8974
X0.253
Y-0.8968
X-0.1069
G2 X-0.1198 Y-0.8935 I0. J0.027
X-0.1217 Y-0.8923 Z-0.0601 I0.0129 J0.0237 F3.3
G1 X-0.1591 Y-0.8677 Z-0.0616
G2 X-0.1847 Y-0.8201 Z-0.0636 I0.0314 J0.0476
X-0.1831 Y-0.8065 Z-0.0641 I0.057 J0.
X-0.4089 Y-0.7189 Z-0.0726 I0.1831 J0.8065
G1 X-0.4075 Y-0.722 Z-0.0727
X-0.1413 Y-0.8974 Z-0.0838
X0.0354 Z-0.09
X0.253 F10.
Y-0.8968
X-0.1069
G1 X-0.4075 Y-0.722
X-0.1413 Y-0.8974
X0.0354
X0.253 Z-0.0976 F3.3
Y-0.8968
X-0.1069 Z-0.1102
G2 X-0.1217 Y-0.8923 Z-0.1107 I0. J0.027
G1 X-0.1591 Y-0.8677 Z-0.1123
G2 X-0.1847 Y-0.8201 Z-0.1143 I0.0314 J0.0476
X-0.1831 Y-0.8065 Z-0.1148 I0.057 J0.
X-0.3258 Y-0.7601 Z-0.12 I0.1831 J0.8065
X-0.4089 Y-0.7189 I0.3258 J0.7601 F10.
G1 X-0.4075 Y-0.722
X-0.1413 Y-0.8974
X0.253
Y-0.8968
X-0.1069
X-0.3258 Y-0.7601 I0.1831 J0.8065
X-0.4089 Y-0.7189 Z-0.1232 I0.3258 J0.7601 F3.3
G1 X-0.4075 Y-0.722 Z-0.1234
X-0.1413 Y-0.8974 Z-0.1345
X0.253 Z-0.1483
Y-0.8968
X0.2039 Z-0.15
X-0.1069 F10.
G1 X-0.4075 Y-0.722
X-0.1413 Y-0.8974
X0.253
Y-0.8968
X0.2039
X-0.1069 Z-0.1609 F3.3
G2 X-0.1217 Y-0.8923 Z-0.1614 I0. J0.027
G1 X-0.1591 Y-0.8677 Z-0.163
G2 X-0.1847 Y-0.8201 Z-0.1649 I0.0314 J0.0476
X-0.1831 Y-0.8065 Z-0.1654 I0.057 J0.
X-0.4089 Y-0.7189 Z-0.1739 I0.1831 J0.8065
G1 X-0.4075 Y-0.722 Z-0.174
X-0.2645 Y-0.8162 Z-0.18
X0.253
Y-0.8968
X-0.1069
G1 X-0.4075 Y-0.722
X-0.2645 Y-0.8162
X-0.1413 Y-0.8974 Z-0.1852 F3.3
X0.253 Z-0.1989
Y-0.8968
X-0.0635 Z-0.21
X-0.1069 F10.
G1 X-0.4075 Y-0.722
X-0.2645 Y-0.8162
X-0.1413 Y-0.8974
X0.253
Y-0.8968
X-0.0635
X-0.1069 Z-0.2115 F3.3
G2 X-0.1217 Y-0.8923 Z-0.2121 I0. J0.027
G1 X-0.1591 Y-0.8677 Z-0.2136
G2 X-0.1847 Y-0.8201 Z-0.2156 I0.0314 J0.0476
X-0.1831 Y-0.8065 Z-0.2161 I0.057 J0.
X-0.4089 Y-0.7189 Z-0.2246 I0.1831 J0.8065
G1 X-0.4075 Y-0.722 Z-0.2247
X-0.1413 Y-0.8974 Z-0.2358
X-0.0214 Z-0.24
X0.253 F10.
Y-0.8968
X-0.0635
X-0.1069
G1 X-0.4075 Y-0.722
X-0.1413 Y-0.8974
X-0.0214
X0.253 Z-0.2496 F3.3
Y-0.8968
X-0.1069 Z-0.2622
G2 X-0.1217 Y-0.8923 Z-0.2627 I0. J0.027
G1 X-0.1591 Y-0.8677 Z-0.2643
G2 X-0.1847 Y-0.8201 Z-0.2663 I0.0314 J0.0476
X-0.1831 Y-0.8065 Z-0.2667 I0.057 J0.
X-0.2729 Y-0.7807 Z-0.27 I0.1831 J0.8065
X-0.4089 Y-0.7189 I0.2729 J0.7807 F10.
G1 X-0.4075 Y-0.722
X-0.1413 Y-0.8974
X0.253
Y-0.8968
X-0.1069
X-0.2729 Y-0.7807 I0.1831 J0.8065
X-0.4089 Y-0.7189 Z-0.2752 I0.2729 J0.7807 F3.3
G1 X-0.4075 Y-0.722 Z-0.2753
X-0.1413 Y-0.8974 Z-0.2865
X0.246 Z-0.3
X0.253 F10.
Y-0.8968
X-0.1069
G1 X-0.4075 Y-0.722
X-0.1413 Y-0.8974
X0.246
X0.253 Z-0.3002 F3.3
Y-0.8968 Z-0.3003
X-0.1069 Z-0.3128
G2 X-0.1217 Y-0.8923 Z-0.3134 I0. J0.027
G1 X-0.1591 Y-0.8677 Z-0.3149
G2 X-0.1847 Y-0.8201 Z-0.3169 I0.0314 J0.0476
X-0.1831 Y-0.8065 Z-0.3174 I0.057 J0.
X-0.4089 Y-0.7189 Z-0.3259 I0.1831 J0.8065
G1 X-0.4075 Y-0.722 Z-0.326
X-0.3119 Y-0.785 Z-0.33
X0.246
X0.253
Y-0.8968
X-0.1069
G1 X-0.4075 Y-0.722
X-0.3119 Y-0.785
X-0.1413 Y-0.8974 Z-0.3371 F3.3
X0.253 Z-0.3509
Y-0.8968
X-0.0068 Z-0.36
X-0.1069 F10.
G1 X-0.4075 Y-0.722
X-0.1413 Y-0.8974
X0.253
Y-0.8968
X-0.0068
X-0.1069 Z-0.3635 F3.3
G2 X-0.1217 Y-0.8923 Z-0.364 I0. J0.027
G1 X-0.1591 Y-0.8677 Z-0.3656
G2 X-0.1847 Y-0.8201 Z-0.3676 I0.0314 J0.0476
X-0.1831 Y-0.8065 Z-0.3681 I0.057 J0.
X-0.4089 Y-0.7189 Z-0.3765 I0.1831 J0.8065
G1 X-0.4075 Y-0.722 Z-0.3767
X-0.3277 Y-0.7746 Z-0.38
X0.253
Y-0.8968
X-0.0068
X-0.1069
G1 X-0.4075 Y-0.722
X-0.3277 Y-0.7746
G3 X-0.3252 Y-0.7754 Z-0.3793 I0.003 J0.0045
X-0.3232 Y-0.7752 Z-0.3773 I0.0004 J0.0054
X-0.3225 Y-0.775 Z-0.3746 I-0.0015 J0.0052
G1 Z0.2
G0 Z0.6
M9
G28 G91 Z0.
G90 G53 X0. Y0.
M30
« Last Edit: June 14, 2014, 07:31:08 PM by Ya-Nvr-No »
