Hello Guest it is November 07, 2026, 03:09:45 AM
Author Topic: Help with general inputs  (Read 28032 times)
« on: June 10, 2014, 06:38:24 PM »
I currently have a number of switches hooked to my Galil DMC 1850 inputs 5,6,7 & 8 on the second ICM.  There is a pendant that I got with my Camsoft that is hooked to the first ICM and for now I want to leave it there.
So I want to hook the switched to the Mach inputs 1-4.  It looks like the terminals on the Galil board ICM1900 are 61-64, but this is board/connector #2. So I am thinking that is actually inputs 9-16, yes?  What do I use for the pins in Mach?
Re: Help with general inputs
« Reply #1 on: June 12, 2014, 08:31:44 AM »
I think I finally have it straight as far as the pins/inputs.
I used pins 37-40 and hooked them to Inputs 1- 4, so I can use them at this point. Those are actually inputs 5-8 on my second board at Galil connections 61-64
Is there a chart anyplace showing the Mach pins and Galil pin assignments?  I suppose it would be different for the various Galil models.
Offline smurph
  •  1,575 1,575
« Reply #2 on: June 18, 2014, 11:05:47 PM »
The pin assignments are in the Galil plugin doc pdf that can be downloaded from the Mach website.
Steve
