Hello Guest it is November 22, 2026, 10:33:22 AM
Author Topic: Mach3 OD Taper wizard  (Read 10082 times)
Offline Rimmel
  •  284 284
« on: June 10, 2014, 08:18:07 AM »
The OD taper wizard seems to assume that the taper is always on the end - e.g. it overshoots on the center.
I am trying to make this shape (see pic) any ideas?
Re: Mach3 OD Taper wizard
« Reply #1 on: June 10, 2014, 02:38:11 PM »
That would have to be done in 3 operations with the wizards.
1. parallel cut to dia at top of taper
2 parallel cut to dia at start of taper
3 taper starting at  end of number 2. parallel cut.
Offline Rimmel
  •  284 284
« Reply #2 on: June 10, 2014, 03:44:38 PM »
Yes, i see that however the taper over shoots on the inner edge.
So if i want the taper to start (widest point - left to right) at 20mm and then reduce down to 10mm. I put this in the wizard and it starts the last cut at X9.77 which is less than the minimum needed. The wizard seems to ignore the X end of 10mm and goes lower to 9.77
see pic
« Last Edit: June 10, 2014, 03:46:22 PM by Rimmel »
« Reply #3 on: June 11, 2014, 07:51:53 PM »
Looks like your only options woulld be to hand code it in that case, or use CAM. Not sure how well LazyTurn works but may be worth a look.
I use BobCAD and quite like it and in the past I used Dolphin and it was also ok.
