Hello Guest it is November 22, 2026, 10:13:38 AM
Author Topic: Threading Wizard help  (Read 11302 times)
Offline bbcnc
  •  12 12
« on: June 09, 2014, 01:09:47 AM »
just realized my first post on this forum was in the wrong spot..Hoping this is a better spot..I tried to lock the first one
I am relatively new to the world of cnc but have been figuring it out by reading and such for awhile.  I can turn pretty accurately and wanted to start practicing threading.  I was having issues with the threading wizard giving me a feed rate error so I moved me Z axis velocity to 75 (which is its max).  I do not get the feed rate error anymore but when I go to run the program, it just jabs my tool into the middle of the stock.  I am pretty familiar with setting up tools and such so i dont think the error is there..I have attached my numbers and g-code to see if someone can help me figure out where my error is out
thanks
Re: Threading Wizard help
« Reply #1 on: June 09, 2014, 12:33:59 PM »
Can you attach your xml please as it will help me see how you have things set up.
Offline bbcnc
  •  12 12
« Reply #2 on: June 09, 2014, 05:57:56 PM »
I think this is correct.  Many of the values are made on my best guess, my manufacturer kinda bailed on me
« Reply #3 on: June 10, 2014, 02:37:09 AM »
Ok first thing to do is go to Config menu then Ports and Pins then Spindle Setup and choose the Use Spindle Feedback in Sync mode.
See if that helps.
« Last Edit: June 10, 2014, 02:38:40 AM by Hood »
Offline bbcnc
  •  12 12
« Reply #4 on: June 10, 2014, 11:44:59 PM »
That did'nt help although I feel I am getting closer to the source of the issue.  When using simple thread wizard and going to run in, I tell the wizard I am using tool 4.  Once I start the program my dRO changes from the offset for tool 4, to something else.  I am not sure what offset it resorts to but it isnt the one I set up for my threading tool
« Reply #5 on: June 11, 2014, 07:49:56 PM »
Wondering if it could be your M6 End macro, make sure it doesnt have anything in it as that is meant for Mills.
