Hello Guest it is November 22, 2026, 09:51:22 AM
Author Topic: Motor Tuning - Maxed out velocity at 84ipm at 45k Hz.  (Read 9130 times)
Offline Vogavt
  •  260 260
« on: June 08, 2014, 02:55:06 PM »
I just made some new brass gibs for my X2 and for the first time ever attempted to go higher rate than I've been on table movement in the past.
I was surprised to see the flag come up that say's velocity requested exceeds blah blah blah limits of configuration.
I know they're are others that are moving at a faster rate than this at 45k Hz and I understand that leadscrew tpi has a lot to do with that.
But does it understand my max feedrate is based upon "steps per" or something?
Where's the bottleneck if it's not in the leadscrew?
Am I missing another setting somewhere?
Don't get me wrong, I'm very happy with the new feedrates, just taken aback that the system is infringing on faster movement.
« Last Edit: June 08, 2014, 02:56:42 PM by Vogavt »
Re: Motor Tuning - Maxed out velocity at 84ipm at 45k Hz.
« Reply #1 on: June 08, 2014, 07:11:32 PM »
That is exactly what the max velocity is determined by, assuming your motors are physically capable of course.
45KHz means that you can output a max of 45,000 steps per second.
Say for example your steps per unit were 4,500 then that would mean that  you could  get a velocity of 10units per second (45.000/4,500), so velocity would be 600 units per minute. (10 units x 60 seconds)
Now if your steps per unit were 9,000 then that would mean you could get a max of 5units per second or 300 units per minute.
« Reply #2 on: June 08, 2014, 07:23:32 PM »
Just to add a wee bit more. Your title says maxed out at 84 IPM.
That would suggest you have a step per unit of approx 32,142.
45,000/ 32,142 = 1.4 units  per second or 84 units per minute
