Hello Guest it is November 22, 2026, 10:14:12 AM
Author Topic: Where are port and pin values Saved  (Read 8497 times)
« on: June 08, 2014, 12:11:50 PM »
Hello
Mach 3 Crashed...   Lost all data.
Tried to use .xml backup file.
Port and Pin data does not seem to be stored there.
Reinstalled Mach 3, used old working .xml file.
No port and pin data, setup.
Not sure if thats all I lost but need this first to get started.
thanks for any help
Mark ???
Re: Where are port and pin values Saved
« Reply #1 on: June 08, 2014, 12:22:00 PM »
The .xml files have all that information. Are you sure you (and Mach3) are using the correct one?
