Hello Guest it is November 22, 2026, 10:04:41 AM
Author Topic: Mach3 Lathe Spindle Stepper . Actual RPM & Set RPM (Snnnn)  (Read 11929 times)
« on: June 07, 2014, 08:17:47 PM »
 Hello All,
 My setup is MACH3 with Smoothstepper. I have attached a stepper motor to my Lathe with a 2:1 gear ratio.
The Motor has  1.8 degree turn / step and I am running with 1/16 micro stepping.
Motor Tuning --> I setup 6400 per rev. I see a 10X difference between the Spindle speed I set with the S command
and the actual RPM ( read it with a spindle encoder ).
I cannot seem to figure what is causing the 10X factor. Any ideas would be very helpful.
Thanks in advance.
Sandeep
Re: Mach3 Lathe Spindle Stepper . Actual RPM & Set RPM (Snnnn)
« Reply #1 on: June 08, 2014, 09:03:10 AM »
Make sure you have the correct speed set for Spindle Pulleys, ie your Max rpm should be the same as the Velocity you have in Motor Tuning for the spindle.
« Reply #2 on: June 08, 2014, 10:18:34 AM »
That was it !! Thank you very much HOOD
Sandeep
« Reply #3 on: June 08, 2014, 07:16:31 PM »
nae probs :)
