Hello
Guest
it is
October 24, 2026, 04:38:20 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
What version of Lua is Mach 4 using?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: What version of Lua is Mach 4 using? (Read 10072 times)
Bodini
216
on:
June 06, 2014, 12:41:33 PM »
Updating to a new version of Lua was mentioned with build 1817. What version is it? I expected to see 5.X in the about box but it says wxLua 2.8.12.3. I don't know what makes one different from the other (don't care either, it will go over my head). All I want to know is which reference manual/examples I should be looking at.
Thanks.
-Nick
mcurtis
2
Re: What version of Lua is Mach 4 using?
Reply #1 on:
June 06, 2014, 01:19:28 PM »
Your seeing the wxLua version (v 2.8.1.3) (wxLua wrap the wxWidgets library v 3.0.0) If you append
Code:
[Select]
.."Lua Version " .. _VERSION
into the about dialog, you should see the Lua version, which is 5.2
Mayanrd
Bodini
216
Reply #2 on:
June 06, 2014, 03:06:26 PM »
Thanks. Yes I see now. I forgot things like that are built in (now i recall seeing things like that in other programs).
F5 + step through it:
Code:
[Select]
print( _VERSION )
poppabear
2,235
Briceville, TN, USA
Reply #3 on:
June 11, 2014, 07:30:27 AM »
Lua is 5.2 in the latest
Print
Pages:
1
Go Up
« previous
next »
