Hello Guest it is November 19, 2026, 03:16:26 PM
Author Topic: IsStill example (M4 version of IsMoving)  (Read 47003 times)
Offline Bodini
  •  216 216
« on: June 04, 2014, 07:16:31 PM »
Or: "How to pause your script while an axis is moving."
Hey! It works in build 1817!
Code: [Select]
||_/\\\\____________/\\\\_____/\\\\\\\\\___________/\\\\\\\\\__/\\\________/\\\____________/\\\____________
||_\/\\\\\\________/\\\\\\___/\\\\\\\\\\\\\______/\\\////////__\/\\\_______\/\\\__________/\\\\\____________
||__\/\\\//\\\____/\\\//\\\__/\\\/////////\\\___/\\\/___________\/\\\_______\/\\\________/\\\/\\\___________
||___\/\\\\///\\\/\\\/_\/\\\_\/\\\_______\/\\\__/\\\_____________\/\\\\\\\\\\\\\\\______/\\\/\/\\\__________
||____\/\\\__\///\\\/___\/\\\_\/\\\\\\\\\\\\\\\_\/\\\_____________\/\\\/////////\\\____/\\\/__\/\\\_________
||_____\/\\\____\///_____\/\\\_\/\\\/////////\\\_\//\\\____________\/\\\_______\/\\\__/\\\\\\\\\\\\\\\\_____
||______\/\\\_____________\/\\\_\/\\\_______\/\\\__\///\\\__________\/\\\_______\/\\\_\///////////\\\//_____
||_______\/\\\_____________\/\\\_\/\\\_______\/\\\____\////\\\\\\\\\_\/\\\_______\/\\\___________\/\\\______
||________\///______________\///__\///________\///________\/////////__\///________\///____________\///______
||  By            ::: NJL Bodini
||  Mach 4 Build  ::: 1817
||  Date          ::: 06 04 2014
||  Script Desc   ::: Pause script execution while an axis is in motion (m4 version of IsMoving )
inst = mc.mcGetInstance()
mc.mcCntlGcodeExecute(inst, "g91 g1 x1") --execute gcode
while (mc.mcCntlIsStill(inst)==1) do  --loops through this while an axis is moving
    mc.mcCntlSetLastError(inst, "axis in motion") --do this while axis is moving
end  --ends the loop
mc.mcCntlSetLastError(inst, "axis is stopped")  --continues here after axis is done moving
mc.mcCntlGcodeExecute(inst, "g90") --execute gcode
Re: IsStill example (M4 version of IsMoving)
« Reply #1 on: June 05, 2014, 10:55:10 AM »
here is what gets me..
mc.mcCntlIsStill(inst)==1, if the axis IS STILL, (i.e. not moving), it should give you a 1, if it IS Moving, it should return a 0.....
seams to me it should ask the question "Are you still?"  1 = yes, 0 = no..
just my own quirks I guess..
BTW:   YOU have FAR, FAR, FAR to much time on your hands for Mach4 Ascii art!!!!  hehehhee
Scott
Offline Bodini
  •  216 216
« Reply #2 on: June 05, 2014, 12:08:53 PM »
Scott
I thought the same thing as you when I tried the script the first time.  But it didn't work, so I flipped 0 for 1 and it did work.  I imagine that the programmers may have something else in mind but that wouldn't be the first time I couldn't follow the logic.  Oh well, once it worked I just accepted it and thats that. ;-)
Scott
I like to give that illusion on the interwebz.  ;D
Code: [Select]
  ____            _   _
 / ___|  ___ ___ | |_| |_
 \___ \ / __/ _ \| __| __|
  ___) | (_| (_) | |_| |_
 |____/ \___\___/ \__|\__|
ascii art generator --> http://patorjk.com/software/taag/
-Nick
Offline Bodini
  •  216 216
« Reply #3 on: June 06, 2014, 09:20:59 PM »
Build 1817: Use IsStill with caution.  It worked OK in the above script, but beyond that it is causing all sorts of problems.
Offline Bodini
  •  216 216
« Reply #4 on: June 07, 2014, 08:12:35 PM »
