Hello Guest it is October 05, 2026, 04:08:57 AM
Author Topic: Help! My "torch on" control is always on. Won't cut current.  (Read 13374 times)
I have a small pro cut plasma table which has been running fine for a while.  Recently the relay of the torch control went bad.  After some fiddling, something happened now there is always current running through the control side of the relay, and it's keeping the relay open all the time... Help please.
Offline Davek0974
  •  2,606 2,606
Re: Help! My "torch on" control is always on. Won't cut current.
« Reply #1 on: May 31, 2014, 01:54:39 PM »
Is it controlled from a smaller relay on a breakout board?
Is this a parallel connected machine?
It is possible the driver for the relay has gone bad and is permanently on, if so a new board could be needed.
« Reply #2 on: May 31, 2014, 02:04:00 PM »
That's kind of what I'm assuming.  I've tested the DC current. From the board that controls the relay, and there is no change when I turn the torch on and off...  That's the only thing I can think other then if something got messed up with the output settings in the computer.
  It is in fact connected with a parallel cable.
Offline Davek0974
  •  2,606 2,606
« Reply #3 on: June 01, 2014, 01:13:16 PM »
In that case, if you shut the PC off and pull the parallel cable, does the relay drop out?
If no then my money is on a fried breakout board, it does happen.
« Reply #4 on: June 01, 2014, 02:00:24 PM »
No it doesn't.  All the motors disconnect, but the relay seems to always be getting a constant dc current.  When I test everything it's like 44vdc up until the relay, then it's like 26 or 33 or something, which I'm assuming is because the coil is contracted or however that works...
Is the breakout board the main board where your motors connect and your parallel cable plug in?  If so I can get another no problem.  I am just going through my due diligence before hand, trying to rule everything else out.
It also could have to do with the board that controls the relay...although I don't think so, because I've tested everything there also.
Offline Davek0974
  •  2,606 2,606
« Reply #5 on: June 03, 2014, 12:37:56 PM »
The breakout board is generally the one with the parallel cable connected.
Any chance of a picture or link?
« Reply #6 on: June 03, 2014, 12:48:30 PM »
No but the problem has been solved.
For future reference. The g540 has 2 outputs.  Only one gets used for my machine.
  I was told to switch the wiring on the board, and designate the output in the computer.
   So far so good.
Offline Davek0974
  •  2,606 2,606
« Reply #7 on: June 03, 2014, 02:42:16 PM »
Nice :)
