Hello Guest it is November 23, 2026, 11:09:46 AM
Author Topic: Read write to a DRO ??  (Read 43162 times)
« on: May 30, 2014, 02:06:56 PM »
How would one read or write to a USER DRO on the screen.
I need to read a #var(I can do that) and update an onscreen DRO(dro18)  . That part I cannt do as I do not find any langeage to create the function.
In mach3 it would be    SetUserDRO(18,  GetVar(590))
ALSO same the otherway around. I need to update a #var(#590) from  DRO value of (DRO18)
in Mach3 it would be SetVar(590, GetUserDro(18))
Offline Bodini
  •  216 216
Re: Read write to a DRO ??
« Reply #1 on: May 30, 2014, 06:32:31 PM »
I just sent you an email with an image regarding your question (couldn't upload the image at the moment).  Hopefully it's what you are looking for.  -Nick
And super quick here out of my notes:
Sending a Property called 'value' to a DRO called 'udro101' with a variable called 'Passval'
Code: [Select]
Passval = 100
scr.SetProperty('udro101', 'Value', tostring(Passval))
*Addendum*  Finally gained access to photobucket.  ::)  I made this quck image for my own purposes.  (As in, i wont remember in a month  ;) )
« Last Edit: May 30, 2014, 06:49:59 PM by Bodini »
« Reply #2 on: May 30, 2014, 07:12:09 PM »
*** reposted from the bug thread...
Terry,
Place a "dro" on your screen, the User Dro you want, for this example Name it:  UDRO20 in its properties window.
then in a button, put this code:
   local inst = mc.mcGetInstance();
   local rc = 0;
   local MyVarVal = 0;
   local MyStgVal = "";
   MyVarVal, rc  = mc.mcCntlGetPoundVar(inst, 590);
   if rc ~= 0 then
      mc.mcSetMachError(inst, "get # err");
   else
      MyStgVal = tostring(MyVarVal);
      rc = scr.SetProperty('UDRO20', 'Value',  MyStgVal );--sets your UDRO to your Param value on the push
   end
--the opposite procedure would go the other way, load your User Dro to your param...
--further, if you want these two things to happen as mach runs automatically, drop them in the PLC scripter, but PLEASE make --sure they run without error before you do
--Scott
Simpson36,
     I did publish some down and dirty "User Manual" for McLua stuff............  while true I am not the "OEM" picked to do an official manual, it should serve to get ya started.
Scott
« Reply #3 on: May 30, 2014, 08:34:19 PM »
Scott could you show an example of the reverse ??
I have been trashing with it sense your earlier response with no luck. I cannot even get this to work. It wants num,num,num  and says I am giving it num,num,string  I have tried about 20 differrnt ways with no luck so far
mc.mcCntlSetPoundVar(inst, 590,123456);
« Reply #4 on: May 30, 2014, 09:22:36 PM »
OK i am down to basics here
SNv  = scr.GetProperty('UDRO20', 'Value' );
wx.wxMessageBox( SNv)
--- At this point I do NOT get a value for the SNv. It is empty no 0 nothing so there is nothing to pass on  AND what there is is a STRING value format.
 mc.mcCntlSetPoundVar(inst, 590, 'SNv' );
-- This call WANTS a number value NOT a string  (SNv). HOW do I conver the string into a NUMBER before I feed it into the call.
« Reply #5 on: May 30, 2014, 09:32:07 PM »
 --read
     local varvalue;
     local val = 0;
     varvalue = mc.mcProfileGetDouble(inst , 'drovar1' , '1', val)
     mc.mcCntlSetPoundVar(inst, 1, varvalue)
--write
     varvalue = mc.mcCntlGetPoundVar(inst, 1);
     mc.mcProfileWriteDouble(inst ,'drovar1','1',varvalue)
--getpound setdro
    scr.SetProperty('drovar1', 'Value', tostring(varvalue));
« Last Edit: May 30, 2014, 09:35:43 PM by Ya-Nvr-No »
« Reply #6 on: May 30, 2014, 09:58:45 PM »
Thnaks Craig I will chew on that.
Here I try it this way BUT it does not make sense of what happens
SN = "987654"
    wx.wxMessageBox( SN)
    --SNv  = scr.GetProperty('UDRO20', 'Value' );
    --wx.wxMessageBox( SNv)
SNv = tonumber(SN)
--ERROR::  wxLua: Expected a 'string' or 'wxString' for parameter 1, but got a 'number'.
--OK Lua says that SNv IS a number RIGHT ? GREAT we are set(;-) BUT not so fast buckshot
--THis call errored with wxLua: Expected a 'number' for parameter 3, but got a 'string'.
--HOW can "SNv" be a number and a String at the same time?  I don't get it.
 wx.wxMessageBox( "Complete")
« Reply #7 on: May 30, 2014, 10:08:50 PM »
no,
the reason your getting an error is your GetProperty of value, returns a Number so your SNv is a number,
wx.wxMessageBox needs SNv to be a string so........
wx.wxMessageBox( tostring(SNv));
Scott
« Reply #8 on: May 30, 2014, 10:24:02 PM »
SCOTT I understand that I used the Messagebox to TEST the VALUES as to IF it is a Number or String  IF it excepts the value it is a string otherwiise the error tells you it is a number.
Craig this does not work here. It sets the #var 590 to 0.0000 when the DRO value is 112233.0000
     local varvalue;
     local val = 0;
     varvalue = mc.mcProfileGetDouble(inst , 'Udro20' , '590', val)
     mc.mcCntlSetPoundVar(inst, 590, varvalue)
« Reply #9 on: May 30, 2014, 10:44:59 PM »
HIYA Craig, THis works correctly THANK YOU very much. Just a though one should not use #1 as #vars 1-34 are local Vars reserved for G65 mcaro calls. YANEVERKNOW what you may get in return when used outside of the G65 call.  (;-)
--getpound setdro
    varvalue = mc.mcCntlGetPoundVar(inst, 590);
    scr.SetProperty('Udro20', 'Value', tostring(varvalue));
« Last Edit: May 30, 2014, 10:48:39 PM by BR549 »
