Hello
Guest
it is
November 22, 2026, 11:15:43 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Softlimits warning... read other posts still stuck.
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Softlimits warning... read other posts still stuck. (Read 19402 times)
Rimmel
284
on:
May 28, 2014, 05:40:48 AM »
Hi, I have a soft limits warning on every single program I run. The program does run fine though.
Background: The lathe Z axis homes to the right of the machine and the X axis homes to the front of the machine on limit/homing switches.
X travel from front (home) to back is 185mm.
Z travel from right (home) to left (spindle) is 444mm.
I have included a screenshot of the homing limits and also the warning screen I get. I have read other Soft limits warning threads but can't see the problem.
Simple G-code:
G18 G21 G64 G80 G90 G40 G49 G94
M6 T0404
M0 ( TOOL 04 )
S750
F25
M3
G4 P0.1
M8
G4 P5
( Start Spring cut 01 )
G0 Z-23.14
G0 X10.5
G1 X5.8
G0 X10.5
( End Spring cut 01 )
( Start Spring cut 02 )
G0 Z-25.64
G1 X5.7
G1 Z-23.14
G1 Z-23.4 X6.0
G0 X10.5
( End Spring cut 02 )
( Part Off )
G0 Z-28.14
G1 X0.0
G0 Z50
G0 X50
M5
M9
M30
Any help appreciated
Last Edit: May 28, 2014, 05:55:39 AM by Rimmel
Carnoustie, Scotland
Re: Softlimits warning... read other posts still stuck.
Reply #1 on:
May 30, 2014, 06:58:50 PM »
What rev of Mach are you using?
Rimmel
284
Reply #2 on:
May 31, 2014, 06:27:45 AM »
Hi, it's Version R3.043.066 (latest from the downloads section on Artsofts site)
thanks
Reply #3 on:
June 01, 2014, 03:14:35 AM »
Try an older version to see if you still have the problem, maybe 057.
Rimmel
284
Reply #4 on:
June 01, 2014, 09:42:55 AM »
I tried 057 but exactly the same happened - got me stumped.
Rimmel
284
Reply #5 on:
June 01, 2014, 10:14:37 AM »
Is there no way to just disable the warning? It's obviously showing the warning in error as the program runs without hitting anything and if I jog to the limits then the switches or the soft limits work fine.
Davek0974
2,606
Reply #6 on:
June 01, 2014, 01:10:51 PM »
Probably not connected but I get this error if I try to start a cut without doing a re-origin first.
If i jog to start position, re-origin the display, then press start it works every time without warning.
This is on a plasma table.
Reply #7 on:
June 05, 2014, 12:39:25 PM »
One or two of the versions had this problem in Turn, try another and see. I thought I used 057 but would have to check to make sure.
I certainly wouldnt use 066 for Turn it has some problems.
Reply #8 on:
June 06, 2014, 03:54:52 AM »
Its 062 I have on the lathe.
Rimmel
284
Reply #9 on:
June 06, 2014, 12:48:33 PM »
Thank you very much.
Print
Pages:
1
2
Go Up
« previous
next »
