Hello Guest it is November 13, 2026, 07:01:21 AM
Author Topic: Is there a way to tell IF gcode is loaded  (Read 11932 times)
Offline Bodini
  •  216 216
« on: May 27, 2014, 10:01:07 PM »
Is there a way for Lua to check IF Mach4 has a gcode file loaded?  ???
Thanks, Nick
Re: Is there a way to tell IF gcode is loaded
« Reply #1 on: May 27, 2014, 10:13:03 PM »
might try
filename = mc.mcCntrlGcodeFile(inst)
or
linecount = mc.mcCntrlGcodeLineCount(inst)
then see if filename = nil
or linecount > 1
Offline Bodini
  •  216 216
« Reply #2 on: May 28, 2014, 06:57:08 AM »
Good thinking, Craig.
Nick
Code: [Select]
inst = mc.mcGetInstance()
local linecount = mc.mcCntlGetGcodeLineCount(inst)
if linecount > 0 then
    wx.wxMessageBox ("File loaded")--file is loaded
else
    wx.wxMessageBox ("No file loaded")--no file loaded
end
« Reply #3 on: May 28, 2014, 07:46:17 AM »
Not sure I'd use zero (0) as the default seems to be 1
think that needs to be addressed at some point before release.
But your welcome
Offline Bodini
  •  216 216
« Reply #4 on: May 28, 2014, 07:52:36 AM »
The Dro says "1" but the var says "0" (since I'm checking the var, then the script works).  Like you say, that should probably be addressed.
