Hello Guest it is November 21, 2026, 01:20:21 AM
Author Topic: Hot Key, space bar  (Read 10727 times)
Offline Quin
  •  34 34
Hot Key, space bar
« on: May 24, 2014, 09:39:13 AM »
The space bar repeats the last button clicked by the mouse.  How can I eliminate this hot key function?  Also is there a way query for all hot key assignments?
thanks,  Quin
(I originally posted this under Mach4 by mistake)
Offline Fastest1
  •  920 920
  • Houston, TX
Re: Hot Key, space bar
« Reply #1 on: May 26, 2014, 02:33:30 PM »
Hotkey assignments are in the config window, under "system hotkeys".
Offline Quin
  •  34 34
« Reply #2 on: May 26, 2014, 08:15:21 PM »
Yes, "config>hot key" does show the hot key assignment for each button, if any.  My problem is that pressing the space bar repeats the last button that was clicked with the mouse.  This is the feature that I want to eliminate, if possible.  Any ideas would be appreciated.
Quin
« Reply #3 on: May 27, 2014, 01:14:00 PM »
The spacebar should be assigned to the FeedHold if using the default screenset. The screenset is where HotKeys for buttons are defined so possibly you are using a non-standard screenset.
« Reply #4 on: May 27, 2014, 07:01:21 PM »
It does the same thing here IF there are no hotkeys defined When you press teh space bar it repeats the last button pressed.
Just assign 1 hotkey and the problem goes away.
Just a thought, (;-) TP
