Hello Guest it is November 10, 2026, 01:56:29 AM
Author Topic: Sleep() doesn't work when called in Macro  (Read 7360 times)
« on: May 21, 2014, 08:13:41 PM »
I am running Mach version 3.043.066.
I have a CS-Labs CSMIO IP/S.
I wrote a macro M301 that I want to use to turn on an air solenoid for one second.  The code is:
SetPulley(1)
Pulley1On = OUTPUT3
Pulley2On = OUTPUT4
DeactivateSignal(Pulley2On)
ActivateSignal(Pulley1On )
Sleep(1000)
DeactivateSignal(Pulley1On )
This works properly when I am in the vbscript editor, but when I call it from MDI, the output is activated, but never deactivated.
Bill
Re: Sleep() doesn't work when called in Macro
« Reply #1 on: May 21, 2014, 11:51:01 PM »
SetPulley(1)
Pulley1On = OUTPUT3
Pulley2On = OUTPUT4
While Ismoving()
Wend
While Ismoving()
Wend
Sleep(1000)
DeactivateSignal(Pulley1On)
While Ismoving()
Wend
« Reply #2 on: May 22, 2014, 01:53:08 PM »
Thanks BR549!  It turns out that one of the problems was that somehow I ended up with two copies of the macro.  One was in the mach3/macros folder and one in the mach3/macros/myprofile folder.  But I see how yours should be more robust.  I look forward to trying it!
Bill
