Hello Guest it is October 02, 2026, 07:48:13 AM
Author Topic: Inputs not working ? IP-S  (Read 10645 times)
« on: May 19, 2014, 12:31:40 AM »
I am not seeing any inputs working (on the box leds or in mach3).
Per the cslabs drawing on wiring basic machine, it shows this
" 4.8 Digital inputs connector (0-15) (CSMIO/IP-S v2)", manual page 17.
Pin 1 input 0 (+) and pin 5 Inputs 0-7 (-).
So having a switch from pin 1. to pin 5 would be correct ?
Or ..
Pin 1, to the +24V line on the power supply.
4.15.3 Illustrative diagram of XYZ plotter (CSMIO/IP-S v2), manual page 24.
I am just trying to get inputs to work.
A wire connected from pin 1 to 5 or from +24v to pin1 both dont work.
No inputs.
Any ideas ?
A longshine stepper drive with differential outputs, and an ac brushless servo drive both work fine.
Re: Inputs not working ? IP-S - Solved by CSlabs
« Reply #1 on: May 19, 2014, 05:15:52 AM »
I got a new manual (V2) immediately.
The 24V PSU needs (-) to go to pin 5, for the inputs.
This solved it.
I was using an old manual.
Case closed.
