Hello Guest it is September 23, 2026, 02:18:42 AM
Author Topic: Variables reading and writing  (Read 59596 times)
Re: Variables reading and writing
« Reply #10 on: May 17, 2014, 12:30:54 PM »
Trust me Craig IF I could do it you would never hear a word out of me on such matters. I would be too busy to chat.
You do know that one does NOT have to do anything I am just describing functions that have proven very usefull over time  ;D
You can ether have a LEXUS or a Model T for a controller which would you like to have.  >:D
Yo HAVE taught me a great deal through examples , and I can take those and make things AS LONG as I have enough examples to work with.
NOW do you know how to install socket moduals into LUA. I need access to the Socket.smtp in order to send alert Emails from Mach4. Native LUA has no such function as far as I can find.
GEES even the lowly CB language can do that  :o
« Reply #11 on: May 17, 2014, 12:35:07 PM »
Brian Should  be able to provide a LIST of ALL the #vars in mach4 AND their description/function. He had to create them so there should be a list.
Just a thought, (;-) TP
« Reply #12 on: May 17, 2014, 01:03:11 PM »
That's above my pay grade (Sockets that what I use to break bolts off)
« Reply #13 on: May 17, 2014, 01:47:09 PM »
OK I do not think we can use Socket moduals here as Brian would have to include them in his Distributable file.
I think, (;-) TP
« Reply #14 on: May 17, 2014, 01:55:21 PM »
ran your little example with variables
« Reply #15 on: May 17, 2014, 03:59:27 PM »
No dought the Var monitor works well I am very pleased to have it. Very hard to test complex parametric code without it.
AND paramateric Gcode in MACH4 WORKS VERY WELL as well.
« Reply #16 on: May 17, 2014, 04:21:20 PM »
so far there are some things that do have some merit, but this learning curve is trial and error most of the time.
« Reply #17 on: May 17, 2014, 05:35:47 PM »
YES it is without DOCUMENTATION. Like wondering in the Desert looking for the OASIS
Here is a NEW Thread Milling Wizard.
« Last Edit: May 17, 2014, 05:39:43 PM by BR549 »
« Reply #18 on: May 17, 2014, 06:21:34 PM »
Or perhaps a new Circular Pocket Wizard. The new G12/13 routines made that one easy .
AND YES I did steal that image(;-)
I do wish the Lua Editor was a bit more friendly. All the crashing makes it HARD to get anything done when it is time to test your code
« Last Edit: May 17, 2014, 06:24:42 PM by BR549 »
« Reply #19 on: May 17, 2014, 07:27:55 PM »
All the whining about Lua and two weeks later he's spitting out wizards. Must not be that hard. ;)
