Hello Guest it is November 13, 2026, 05:55:39 PM
Author Topic: Pokeys as MPG screen flickers  (Read 11630 times)
« on: May 11, 2014, 12:07:18 PM »
At this moment I'm using a pokeys (56U) as input device only for a MPG.
The MPG works. I'm able to control all three axes. However at each mpg tick the Mach3 screen flickers. (using MACH3 ver. 3.043).
Only the Mach3 screen flickers, the menu bar and others windows are not flickering.
Mark
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pokeys as MPG screen flickers
« Reply #1 on: May 12, 2014, 02:03:12 AM »
Unfortunately, we can not observe any flickering of Mach3 window. This is a Mach3 issue with refreshing. Do you have the latest 3.043.066 version?
