Hello Guest it is November 07, 2026, 01:37:23 AM
Author Topic: Suggestion for Mill Wizard  (Read 20360 times)
« on: May 11, 2014, 04:38:16 AM »
I Like to use mill wizard where possible
I think a mirror function in engrave would be good.
I am deep engraving the rear of acrylic to led light from underneath for a nice LED sign.
But need mirror in engrave please.
Thanks in advance graemecns
  •  9,375 9,375
Re: Suggestion for Mill Wizard
« Reply #1 on: May 11, 2014, 10:58:19 AM »
Hi graemecns,
If you change the X axis Scale DRO from +1.0000 to -1.0000 that will do it (if you have chosen bottom left for the origin X zero, Y zero that will change to bottom right but if you have chosen the centre of the work as the origin then there is no problem).
Hope this helps.
« Reply #2 on: May 11, 2014, 05:22:57 PM »
thank you for your reply
I had also contacted Brett at customer support but had trouble understanding his initial reply.
He then sent me some screen shots I now understand.
Make Gcode in Mill wizard then open in Mach3.
then change the DRO on X axis scale to neg -  .
Will engrave Mirror.
graemecns
« Reply #3 on: May 12, 2014, 07:00:09 AM »
I will look at the possibility of adding a mirror function to the wizard, it sounds useful. I suppose both mirror in X and Y would be useful?
« Reply #4 on: May 12, 2014, 09:30:47 PM »
hi Ron
the work around is ok if I the complete job can be reversed
But the mirror would be good could then see finished job in mill wizard as it would look
eg.engraved then cut .
Graemecns
