Hello Guest it is October 28, 2026, 05:02:21 PM
Author Topic: Viewing #var values  (Read 45474 times)
Viewing #var values
« on: May 06, 2014, 12:03:10 AM »
Is there anyway to view a #var value ? or a system #var for that matter. Can the Value be written to the status bar ??
In mach3 we had a Var monitor and I had a VarValue report I could run to check on things.
Can we generate a #3000 error in Mach4 and it stop the program with message ? or feedhold?
Just a thought, (;-) TP
« Last Edit: May 06, 2014, 12:05:55 AM by BR549 »
Offline smurph
  •  1,575 1,575
Re: Viewing #var values
« Reply #1 on: May 06, 2014, 12:23:04 AM »
You can make a screen page (or even a tab) that displays any G code var you want.  But I am working on a G code var plugin that will pop a floating window up much like the Diagnostics windows for mcRegFile and mcModbus.  Where you can "pin it" as always on top or not.
And I'm working on the #3000 stuff.  Just trying to get the more pressing issues looked at first.
Steve
