Hello Guest it is October 25, 2026, 04:38:05 PM
Author Topic: Parallel Port Tester. (Software)You can use to trouble your parallel port  (Read 13702 times)
Hi :)
Anytime I change to a different PC my biggest problem is setting up my parallel port. Just found this software
and tried it. Just create a directory in windows / program directory. Make certain the dll is placed in the same
directory as the drivertest.exe. I used windows 7 and it worked great
http://www.downtowndougbrown.com/2013/06/parallel-port-tester/
In recent times device manager has always given me enough info to sort out parallel ports along with my old break-out box, it was a different matter back in the day when your IO was generally a separate card and you had to manually jumper everything to avoid conflicts with any fixed address hardware ;-)
 - Nick
Re: Parallel Port Tester. (Software)You can use to trouble your parallel port
« Reply #2 on: February 01, 2015, 12:38:22 PM »
Works great for testing the port.
