Hello Guest it is October 16, 2026, 10:09:17 PM
Author Topic: Mach4 Fixture screen  (Read 50519 times)
« on: May 03, 2014, 12:04:11 PM »
I was playing around and was wondering if there was a way to call up the fixture screen.
I see where you can load a different file mc.mcFixtureLoadFile(number mInst, string FileToLoad).
But i could not figure out how to pull up the screen with a button script.
I also did not see a call in the drop downs.
Is there a way.  Makes it nice to have a button on the screen for a touch screen.
Glenn
Re: Mach4 Fixture screen
« Reply #1 on: May 03, 2014, 02:15:57 PM »
I added a button command to show the fixture dialog ( will be in the next version). I did not add Lua call to do it.. If I add a Lua call it will need to be from the scr. module
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: May 03, 2014, 05:24:05 PM »
Brian
Perfect thanks.
That is all I will really need.
Just saving up my cash for the release.
Thanks again
Glenn
