Hello Guest it is November 10, 2026, 02:50:26 AM
Author Topic: Cannot create new profile in Mach3  (Read 14692 times)
« on: May 01, 2014, 08:45:20 AM »
I am trying to create a new profile in Mach 3.  When I do, one of two things happen:
1.  Nothing
2.  A blank line is generated a the top of the profile list
I am running the latest version of Mach3, Ethernet Smoothstepper, Windows 7 64-bit.  I am logged in as system administrator, and have granted Mach3 full control priviledges.
I have reinstalled Mach3 several times, and the last time in a different folder (Mach3A).
I need to create a new profile in order to install Calypso MSM, which requires a new profile.  The problem before trying to install Calypso MSM.
Any ideas out there?
Re: Cannot create new profile in Mach3
« Reply #1 on: May 01, 2014, 09:03:55 AM »
Create a new desktop shortcut, with the target being C:\Mach3 /p newprofilename
When youstart mach3 from the shortcut, a new profile will be created.
« Reply #2 on: May 01, 2014, 09:40:16 AM »
I will give that a try.  Thanks.   In the regular dialog there is a checkbox which will use defaults when checked.  Does your process assume checked or not checked in that box?  I need it to be unchecked.
Thanks again.
« Reply #3 on: May 01, 2014, 10:20:40 AM »
Sorry, but that did not work.
« Reply #4 on: May 01, 2014, 10:21:07 AM »
It creates a clean, blank profile.
« Reply #5 on: May 01, 2014, 10:22:25 AM »
sorry, it's C:\Mach3\Mach3.exe /p profilename
« Reply #6 on: May 01, 2014, 10:41:29 AM »
Tried that.  Note the blank line on the top of the profile list
