Hello
Guest
it is
August 14, 2026, 02:35:27 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
hand controllers which is best
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: hand controllers which is best (Read 11677 times)
Learn
75
on:
May 01, 2014, 04:20:54 AM »
which Hand controller works best for you ? If you can post links to which controllers you have and use.
I am trying to get some ideas here.
I would like to get a controller that has the following
motion hold
feed dial
rapid dial
cycle start
Fastest1
920
Houston, TX
Re: hand controllers which is best
Reply #1 on:
May 01, 2014, 09:20:18 AM »
It really depends on how much money you want to spend and or how industrial or durable it needs to be.
I have run the Shuttle Pro as a pendant for years and it works pretty well. The plugin allows setting of all of the buttons and most commands are available (view the plugin on Mach' site). It works well for the price, it is delicate.
I also ran a pendant from CNC4PC on a 2nd parallel port years ago. I found it to be very laggy and it just didnt feel right. The pendant itself was nice and durable, nice MPG and all. I gave up then and moved on. In hindsight and after a conversation with Arturo, I was most likely having computer or configuration problems.
This week I ordered a VistaCnc PS2E. It should be here by the weekend and from the videos i have seen on its performance it appears very well made and operates well. Plus it is USB. Physically the pendant itself appears similar to the CNC4PC unit however the model I ordered has a LCD screen for DRO's onboard.
Vistacnc.com
Learn
75
Reply #2 on:
May 01, 2014, 11:33:31 AM »
thanks for the reply ^^^
HimyKabibble
1,687
Reply #3 on:
May 01, 2014, 01:43:38 PM »
You won't go wrong with VistaCNC. I've been using their pendants for years, and love them. Avoid the Chinese junk, and avoid the ShuttlePro - it's better than nothing, but compared to a real CNC pendant, it's a joke.
Learn
75
Reply #4 on:
May 01, 2014, 03:33:04 PM »
Yeah I am a cnc operator / programmer by trade so I'm just starting out with this ih cnc . Once I get it going
Learn
75
Reply #5 on:
May 03, 2014, 09:11:48 AM »
I have a shuttle express that came with the mill but I can't find the proper plug in for it on the mach 3 page
Learn
75
Reply #6 on:
May 05, 2014, 08:00:17 AM »
Ok after a quick search YouTube has me going fine with the express. I will use that for a while and go from there . Damn the keyboard was rough lol since I am used to big mills with controllers lol
Print
Pages:
1
Go Up
« previous
next »
