Hello
Guest
it is
November 22, 2026, 08:18:03 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Is this a suitable power supply
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Is this a suitable power supply (Read 21510 times)
piccyman
37
on:
April 20, 2014, 01:02:50 PM »
I have bought a
http://www.cnc4you.co.uk/index.php?route=product/product&product_id=280
48V 12A CNC Power Supply
Do you think that this power supply is too higher voltage for the kit i have, 3 nema 23's and 1 nema 17
I have attached the spec on the 3 nema 23 motors and the motor driver
Thank you
JohnHaine
975
Reply #1 on:
April 20, 2014, 05:15:42 PM »
It's the current that fries the motors not the voltage. Do the drivers have provision to set the motor current? Can you provide a link to the driver details?
Sent from my iPad using
Tapatalk
HimyKabibble
1,687
Re: Is this a suitable power supply
Reply #2 on:
April 20, 2014, 08:34:18 PM »
48V is just about perfect for the NEMA23s. Voltage should be 32 * SQRT(MotorInductance), which, in this case comes out to 50V.
piccyman
37
Reply #3 on:
April 21, 2014, 02:00:35 AM »
There is a pot on board that will adjust the current from .5A to 4.5A
http://www.mib-instruments.com/servlet/the-3453/TB6600-Stepper-Motor-Driver/Detail
Thank you
JohnHaine
975
Reply #4 on:
April 21, 2014, 03:43:32 AM »
That looks like a useful driver. Set the current pot to the rated current for your motors before powering up.
It goes without saying I guess, but mount the board in the vertical plane so that air can convect past the heatsink.
stirling
2,188
UK
Reply #5 on:
April 21, 2014, 04:43:22 AM »
The page you linked to for the driver appears to give a range of 12 to 36V. The datasheet for the TB6600HG's gives an absolute max rating of 42V so the 36V seems appropriate. There are several warnings on the data sheet about the consequences of going over this absolute max of 42V - most of which seem to involve some form of mayhem
Ian
Razordance Torch Height Control
piccyman
37
Reply #6 on:
April 21, 2014, 04:48:03 AM »
i saw that, except the Toshba spec is 50v for the chip and in the documentation that came with the drivers states 50v
piccyman
37
Reply #7 on:
April 21, 2014, 05:19:40 AM »
http://www.toshiba-components.com/docs/linear/TB6600HG_en_datasheet.pdf
this data sheet?
Do you think i should find a lower voltage supply? like 36v
Last Edit: April 21, 2014, 05:26:45 AM by piccyman
Picengraver
343
Reply #8 on:
April 21, 2014, 05:41:46 AM »
"The power supply voltage of 42 V and the output current of 4.5 A are the maximum values of operating range."
This quote is from the data sheet you referenced. The 50V is not an operating voltage. Stay safe, use 36v or 24v.
John Champlain
www.picengrave.com
piccyman
37
Reply #9 on:
April 21, 2014, 05:43:05 AM »
ok, thank you
Print
Pages:
1
2
Go Up
« previous
next »
