Hello Guest it is October 25, 2026, 10:40:07 AM
Author Topic: Moving part origin  (Read 9378 times)
Offline ZASto
  •  434 434
Moving part origin
« on: April 19, 2014, 05:25:28 PM »
Happy Easter everybody!
I have an Chinese made router, distributed by IEHK (www.iehk.net) that, a week or so ago, I converted from pendant controller RZ********* to mach3 control.
Just to mention, I'm an electronic guy so I made my own BOB (original pendant has differential outputs, so the BOB that I made is converting LPT port Step and Dir signals to differential ones).
Today, I started a job which is 350 x 450 mm and has 7 roughing passes and one finishing.
After tool change for a finishing pass I've noticed that my origin has moved approx 0.4 mm per pass, approx 3 mm in total, both in X and Y direction. Haven't been by machine all the time, but I guess that the move occurred after every pass.
Machine is servo driven with 2.2 kW water cooled spindle.
Could not figure what caused this moving of work origin.
Attached .xml
And, screenset is Blue Tex with some scripts modified
Make no mistake between my personality and my attitude.
My personality is who I am.
My attitude depends on who you are.
Offline ZASto
  •  434 434
Re: Moving part origin
« Reply #1 on: April 23, 2014, 03:37:13 PM »
Yesterday I made a simple code to "touch" 4 points 500 x 500 mm apart, repeating the process 50 times, and the tool made the touch points spot on :(
Offline ZASto
  •  434 434
« Reply #2 on: June 07, 2014, 01:55:28 PM »
Arrrrggggggghhhhhhhhhh :(
One good
http://zastos.biz/ForShare/20140607_144323.jpg
And one BAD, again
http://zastos.biz/ForShare/20140607_144334.jpg
Does anyone have a clue what could make such result?
