Hello Guest it is November 13, 2026, 01:00:23 PM
Author Topic: Breakout Board input, just a thought...  (Read 16253 times)
Offline Davek0974
  •  2,606 2,606
« on: April 10, 2014, 01:42:24 AM »
It seems that the standard boards are limited to the 5 input lines on a LPT port, is it not possible to use these lines as a 5 bit word, that would give us 32 possible inputs (i think) but would need a little change or secondary add-on to the breakout board plus a decoder at the Mach3 end.
Just a thought, the breakout board end id simple as it can be a secondary encoder board connected to the standard input lines, Mach on the other hand I don't know about.
« Last Edit: April 10, 2014, 01:45:12 AM by Davek0974 »
Re: Breakout Board input, just a thought...
« Reply #1 on: April 10, 2014, 02:37:15 AM »
Get a second port or an external controller and you can have many more inputs.
Offline Davek0974
  •  2,606 2,606
« Reply #2 on: April 10, 2014, 02:46:11 AM »
Ah but second port = two cables to the PC plus another BOB etc, external controller=£££
Just wondering :)
« Reply #3 on: April 10, 2014, 04:10:09 AM »
Just wondering :)
Yes, but just remember where you started and how much extra things have cost so far by saving money at the start ;)
I certainly know when I started I bought  cheap and ended up having to buy further to get what I wanted, ie initial cheap stuff was crap and money wasted.
Offline Davek0974
  •  2,606 2,606
« Reply #4 on: April 10, 2014, 04:18:42 AM »
Just wondering :)
Of course, some you win some you lose :)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #5 on: April 10, 2014, 05:27:26 AM »
There is a system out there (ironically enough) yet another THC that I believe does multiplex parallel port I/O in some way or another. To me it seems unnecessarily complex.
« Reply #6 on: April 10, 2014, 05:40:33 AM »
I think the PMDX 126 BOB also does it but that would require you having to purchase another BOB so.....
Offline Davek0974
  •  2,606 2,606
« Reply #7 on: April 10, 2014, 05:48:28 AM »
They do say there is no such thing as new idea :)
