Hello Guest it is October 21, 2026, 10:55:10 AM
Author Topic: 3D printing with Mach 3  (Read 29904 times)
Offline Fastest1
  •  920 920
  • Houston, TX
Re: 3D printing with Mach 3
« Reply #10 on: April 14, 2014, 12:16:50 PM »
Or you can do an edit all E's in the gcode and change to A. Or edit your post processor. I dont remember having issues with Mach 3 and printing.
« Reply #11 on: April 14, 2014, 12:47:34 PM »
I finally figured out my confusion when i got some g-code from someone else.  Apparently the g-code i generated myself left out all the extruder E commands. So now i see what i need to do.
« Reply #12 on: June 20, 2016, 01:36:57 PM »
using slic 3r for g code but mach3 z axes is giving + when it should be - how to change I have tried the hot keys but that does not work the z axes should be lifting not going down help please
« Reply #13 on: June 21, 2016, 09:49:02 AM »
Keith,  Config Homing/limits   In the Z row change the setting in the reversed column.
« Reply #14 on: June 21, 2016, 12:06:35 PM »
Keith, after rereading your question..... In 3D printing the base of your table is the Z zero point.  Anything above that is a positive number.   So any and all 3D printing will be positive numbers as the Z axis moves up.  In mach 3 when you press the page up or Z+ jog button, the Z should go up.  You only reverse the axis travel direction if when jogging up, the Z goes down.
