Hello Guest it is November 17, 2026, 11:50:29 AM
Author Topic: NC Pod Ports and Pins questions  (Read 39356 times)
« on: March 13, 2007, 02:28:15 AM »
I just got the pod in, and some Gecko 201s and was going through the setup process and I have run into a stumbling block.
I set up the pod and got it talking to the latest version of Mach.
I can turn on and off some of the inputs.
Before I attempted to hook up the Geckos, I wrote a simple program to move the X axis back and forth and them put my scope on the outputs for the step and direction.  All I get is  steady 5 VDC.
What should the Port and Pin configuration for the Motor outputs be set to?
Re: NC Pod Ports and Pins questions
« Reply #1 on: March 13, 2007, 08:39:10 AM »
« Reply #2 on: March 13, 2007, 09:30:32 AM »
Thank you,
I thought that I had read every post, but I missed the second page of that post.
« Reply #3 on: September 20, 2007, 06:01:53 AM »
I do not understand English well.
I win a number item by item and can write it intelligibly?
It is hard to understand the next contents.
"What should the Port and Pin configuration for the Motor outputs be set to?"
