Hello Guest it is November 13, 2026, 01:45:19 PM
Author Topic: THC Codes upset corners???  (Read 91206 times)
Offline Davek0974
  •  2,606 2,606
« on: April 03, 2014, 09:49:21 AM »
In preparation for fitting a THC unit, I thought I'd try adding the M101/M102 THC on/off codes to my sheetcam post.
I have a test job, a 50mm square that has 5mm loops on the corners to keep nice sharp corners, however with the THC M codes added, when I dry-run this code in Mach3 Plasma it runs to a corner, stops, cuts the loop, stops, cuts the next edge then repeats on all corners??
Is there a reason it does this or is Mach not set correctly, surely just adding THC on/off codes should not upset the smoothness of the code?
Without the codes it runs smoothly????
Re: THC Codes upset corners???
« Reply #1 on: April 03, 2014, 03:53:15 PM »
Try using G64 at the beginning of your code.
G64 = constant velocity
G61 = exact stop
Jeff
« Reply #2 on: April 03, 2014, 03:55:27 PM »
what is in the m101/102 macros?
Offline Davek0974
  •  2,606 2,606
« Reply #3 on: April 04, 2014, 01:17:01 AM »
G61 = exact stop
Jeff
Neither of those codes appear in my G-code, I will add the G64
Offline Davek0974
  •  2,606 2,606
« Reply #4 on: April 04, 2014, 01:17:37 AM »
Good point, I presumed they were standard Mach macros?
I will have a look
« Reply #5 on: April 04, 2014, 01:48:12 AM »
Macros over 100 are user macros so they are not standard.
Offline Davek0974
  •  2,606 2,606
« Reply #6 on: April 04, 2014, 01:52:04 AM »
Ah, My bad. :)
Is there a "Proper way" to do THC on/off???
Offline Davek0974
  •  2,606 2,606
« Reply #7 on: April 04, 2014, 02:44:44 AM »
Just checked and there are no M101/102 macros in the macros folder, would that explain the behaviour ??
How is this feature enabled??
Offline Davek0974
  •  2,606 2,606
« Reply #8 on: April 04, 2014, 04:00:46 AM »
Just tried creating a couple of macros, 101 & 102, inside i just placed DoOEMButton(222) Or (223)
It makes no difference, the movement still pauses for probably 10-20ms then starts again at each direction change.
The G-code looks identical, just has M101/2 sprinkled about in it.
« Reply #9 on: April 04, 2014, 06:05:34 AM »
Having ANY m call will delay things, Mach needs to process the info and can not possibly continue at a  CV due to that.
Depending on what you are actually doing with the THC signal ( I dont know much abot plasma) you may be able to use m11/m10, with tem there should be no delay.
