Hello Guest it is November 27, 2026, 09:33:19 AM
Author Topic: ECC 4th Axis Test  (Read 32577 times)
ECC 4th Axis Test
« on: April 01, 2014, 04:19:01 AM »
I've finally got the Ebay Cheap Chinese 4th up and running with the help of a compatible driver board from Routout CNC, this video shows some testing for a part I'm currently manually machining, two sides have been faced, the compound curved section has been roughed out with a 6mm 2 flute endmill and part of the first pass with a 6mm 2 flute ball end mill is shown.
I now have to machine a permanent plate for the 4th axis & it's tailstock with eccentric buttons underneath to fit the table slots for axis alignment and Y position plus one for X position.
Apologies for the ropey camera work, also the video quality was far better before uploading to Photobucket :-\
 - Nick
« Last Edit: April 01, 2014, 04:26:20 AM by magicniner »
Re: ECC 4th Axis Test
« Reply #1 on: April 14, 2015, 11:20:15 PM »
Its not really doing any 4th Axis work though.
« Reply #2 on: April 15, 2015, 03:24:53 AM »
Facing 2 sides and roughing the curve were carried out as indexed paths, at -90, +90 and 0
On the path cutting in the video there is A-Axis movement but the video from my phone didn't show it very well, it's only a little but then all that's necessary on a longitudinal path like that is to keep the ball end cutter optimally presented to the work.
In short, yes it is ;-)
Nick
