Hello Guest it is November 13, 2026, 11:03:31 AM
Author Topic: FeedHold restart?  (Read 9670 times)
FeedHold restart?
« on: March 11, 2007, 09:14:57 PM »
Hi, Using Version 2.55 I notice that to restart from feedhold I have to press stop then start. Any one else notice this? Or am I doing something wrong?
This is OK except that the spindle stops and then does not re-start when I press start. So it is a little dangerous? Why can't it be like the older versions where, after feedhold, just pressing start get things going again? This is far more natural I think? Or is there a setting to adjust this I've missed?
Also, it still does not re-start correctly on arcs.  And, if you feed hold twice on an arc, it goes off on a completely different tangent! I think this was being worked on. Can you let us know how it's going?
Apart from this, Mach3 is working just great.
Thanks!
Richard.
Re: FeedHold restart?
« Reply #1 on: March 12, 2007, 02:41:37 PM »
Woody? Same situation here..
I stop and Cycle start. stopped using feedhold. But rad ...Differs from line********* drives batty :)
Mebee I also have not read the manuals.
Apart from that? I I have a "CLEAN" dxf drawing? it works like a charm
