Hello Guest it is November 22, 2026, 02:27:51 PM
Author Topic: large circles in M3  (Read 13028 times)
large circles in M3
« on: March 15, 2014, 12:26:56 PM »
I am just getting started with Mach3. Not sure if this is the right place to post this, but I am having a problem with gcode.
I am using Cut3d to generate cutting paths. When the part is cut on my mill I am seeing big circles, which is not the intent. I can also see these circles in the mach 3 window:
The gcode looks fine when viewed in cutviewer:
Re: large circles in M3
« Reply #1 on: March 15, 2014, 12:31:20 PM »
Reverse your I J setting under Config / General Config.
See if that helps,
Russ
« Reply #2 on: March 16, 2014, 09:36:22 AM »
Thanks Russ,
I am not sure I understand what to reverse on the gen config page. Can you point out this setting?
« Reply #3 on: March 16, 2014, 09:49:41 AM »
Set IJ Mode to Inc (Incremental)
« Reply #4 on: March 16, 2014, 11:07:28 AM »
That worked! Much thanks Russ and Gerry.
« Reply #5 on: March 16, 2014, 11:24:20 AM »
Heyyyyyyyy ... MUCH better !
Very nice.
Be sure to post pics of some of your cool projects, if able.
Russ
