Hello Guest it is October 16, 2026, 07:24:03 AM
Author Topic: Pulse Coder- Way too many wires!  (Read 13744 times)
DNB
« on: March 11, 2007, 01:05:14 AM »
Hi all,
So I was tearing my machine apart and strategizing my retrofit today.  Things were going along fine until I took a close look at the wires coming from the pulse coder.  I was expecting anywhere from 4 to 8 wires depending on what type of pulse coder I have (single-ended or differential encoder).  However, there were 20 plus wires!  I am hoping one of you guys could take a look at the pics I posted below and let me know what I am dealing with and how I should handle these various wires.  Thanks much!
Motor:  Fanuc Model 0 DC Brush motor
Encoder: 2500 Pulse Count
Excit. Perm. Magnet
RPM: 2000
Volts: 56V
Cont Amps at Stall: 12A
Torque at Stall: 2.7Nm
Re: Pulse Coder- Way too many wires!
« Reply #1 on: March 11, 2007, 05:40:13 AM »
If you look inside the motor these are the only ones used.
MS3102A20-29P (encoder connector at motor)
A) A
B) B
C) +5V
D) A not
E) B not
F) Z
G) Z not
H) Shield?
J) +5V
K) +5V
L)
M)
N) 0V
P) 0V
R) Temp Sw.
S) Temp Sw.
T) 0V
Darek
DNB
« Reply #2 on: March 11, 2007, 10:46:16 AM »
Thanks Darek!
DNB
« Reply #3 on: March 11, 2007, 11:08:26 AM »
Hi Darek,
Does Z = Index?
Also, how do the Temp switches work?  Do I use them as emergency stops if the motor gets too hot?
Thanks!
David
« Reply #4 on: March 11, 2007, 01:04:48 PM »
yes:
Z = Index, and your temp switchs are for over temp. Check your switch type, (n/c, or n/o), and you can wire them in your estop.
« Reply #5 on: March 27, 2007, 02:47:42 PM »
Hi David,
Can you tell me the status of your work, any good news? I want to do also a retrofit to my Mazak HMC, with fanuc 6BM control. It is exactly what you are doing, also with F/V converter. Can you give me pointers on what to buy and how to wire them?
I am following your treads with enthusiasm.
Thank You
George
