Hello Guest it is October 25, 2026, 04:38:36 PM
Author Topic: Mach3 running multiple tap files?  (Read 9057 times)
Offline Rimmel
  •  284 284
« on: March 11, 2014, 02:36:13 PM »
I have a part and I need to start one program (tap) then do a manual broach and then finish the part with another program (tap).
At present to change the tap file I close the auto screen and then go back to it. How can i load another tap without going off the auto screen?
thanks
Rim
Re: Mach3 running multiple tap files?
« Reply #1 on: March 11, 2014, 11:44:23 PM »
Hi Rim,
  I assume you mean the Turn screen ? The Auto / Cycle screen page ?
If so, you can load code from the File menu up top without leaving that screen page.
Russ
Offline Rimmel
  •  284 284
« Reply #2 on: March 12, 2014, 05:20:30 AM »
Ah - yes brilliant
thank you
