Hello Guest it is September 09, 2026, 08:46:24 AM
Author Topic: Does the CSLabs CSMIO IP/S do CSS?  (Read 14765 times)
« on: March 10, 2014, 04:57:27 PM »
I am retrofitting a lathe with the CSMIO IP/S with Mach3.  I've heard that Mach4 will to constant surface speed, but want to start using the lathe right away.  Will the IP/S and Mach3 do constant surface speed?
Bill
Re: Does the CSLabs CSMIO IP/S do CSS?
« Reply #1 on: March 10, 2014, 05:34:41 PM »
Mach3 does not do CSS properly, doesnt matter what controller you use.
« Reply #2 on: March 11, 2014, 10:45:30 AM »
Thanks Hood,  I wonder when Mach4 Turn will be available?
« Reply #3 on: March 11, 2014, 03:58:59 PM »
Ha ha, how long is a piece of string?
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #4 on: March 13, 2014, 09:49:40 AM »
Hood, You know that if you right click on the Mach icon and hit rename, you can have Mach 4 now.
« Reply #5 on: March 13, 2014, 02:36:32 PM »
Dindt know that, just tried,  weirdly  it still does CSS as Mach 3 does ;)
