Hello Guest it is November 22, 2026, 07:07:26 AM
Author Topic: Help needed with Mach 3 Driver  (Read 11414 times)
« on: March 08, 2014, 04:59:49 PM »
I can not get the driver to install in the mach 3 demo mode.  Is this normal?  Do you need a license to test your machine?
Re: Help needed with Mach 3 Driver
« Reply #1 on: March 08, 2014, 05:04:46 PM »
Are you using a 64bit OS? If so, you need a 32bit OS to run the Mach3 parallel port driver.
« Reply #2 on: March 08, 2014, 05:48:50 PM »
Yes I am running a 64 bit
« Reply #3 on: March 08, 2014, 05:51:18 PM »
Is there anyway I can get the 64 to run correctly
« Reply #4 on: March 08, 2014, 05:55:11 PM »
No. THe only way to use Mach3 with a 64bit OS is to use an external motion controller, like a Smoothstepper or a UC100.
« Reply #5 on: March 10, 2014, 06:56:59 AM »
Thanks for the help.  Purchased a UC100.
