Hello Guest it is November 29, 2026, 05:34:03 PM
Author Topic: Please Help  (Read 6973 times)
Please Help
« on: March 07, 2014, 08:28:13 PM »
Need help with this code. Where how do I input the variables?
' Auto Tool Zero by Dale Walsh <dale@daleenterprise.com>
Dim Initial_Abs_Inc
Dim Initial_Feed_Rate
Dim Initial_G_State
Dim Initial_Machine_Coordinates_State
Dim Initial_Spindle_CW_State
Dim Initial_Spindle_CCW_State
Dim Initial_Spindle_State
Dim Initial_Tool_Offset_State
Dim Probing_Feed_Rate
Dim Guage_Block_Height
Dim Z_Probe_Pos
Initial_Feed_Rate = GetOEMDRO(818)
Initial_G_State = GetOEMDRO(819)
Initial_Machine_Coordinates_State = GetOEMLed(16)
Initial_Tool_Offset_State = GetOEMLED(28)
Initial_Abs_Inc = GetOEMDRO(48)
Guage_Block_Height = GetOEMDRO(1001)
If Guage_Block_Height <= 0 Then
   Answer = MsgBox("A positive value must be entered for the Guage Block Height", 0, "Oh-oh")
   Exit Sub
End If
If GetOEMDRO(824) <= 0 Then
   Answer = MsgBox("A Tool has not been selected, select a tool and try again.", 0, "Oh-oh")
   Exit Sub
End If
If IsSuchSignal(22) Then ' Check whether a probe input is defined..
   If GetOEMLed(825) = 0 Then
      Answer = MsgBox("Do you need to Move X, Y or Z ?", 4, "Do you need to Move")
      If Answer = 6 Then
         Message("Tool zeroing to Material was canceled so you can move.")
         Exit Sub
      End If
      Answer = MsgBox("Place Sensor on work piece.", 1, "Is the Guage Block Sensor in place")
      If Answer = 2 Then
         Message("Tool zeroing to Material was canceled.")
         Exit Sub
      End If
      Message("Tool zeroing to Material is requested.")
      ' Save settings for restoring later
      Initial_Spindle_State = GetOEMLED(11)
      Initial_Spindle_CW_State = GetOEMLED(164)
      Initial_Spindle_CCW_State = GetOEMLED(165)
      If Initial_Spindle_State = true Then  ' Spindle is running so stop it
         If Initial_Spindle_CW_State = Initial_Spindle_CCW_State Then
            MsgBox("Your running spindle is misconfigured -> clockwise = " &  Initial_Spindle_CW_State & " and counter-clockwise" &  Initial_Spindle_CCW_State & " , please fix this.")
            Exit Sub
         End If
         DoSpinStop()
         Sleep(500)
      End if
      ' Turn off Tool Offset if it's on
      Select Case Initial_Tool_Offset_State
         Case True
            DoOEMButton(136)
      End Select
      Select Case Initial_Machine_Coordinates_State
         Case True
            DoOEMButton(180)
      End Select
      '  Get current scale settings.
      XScale = GetOEMDRO(59)
      YScale = GetOEMDRO(60)
      ZScale = GetOEMDRO(61)
      '  Set scale to one to probe.
      Call SetOEMDRO(59, 1)
      Call SetOEMDRO(60, 1)
      Call SetOEMDRO(61, 1)
      Select Case GetOEMLED(802)
         Case true ' Metric System
            Probing_Feed_Rate = 150
            Probe_Travel = 250
         Case false ' Imperial System
            Probing_Feed_Rate = 6
            Probe_Travel = 10
      End Select
      DoOemButton(1010)
      Code "G4 P1"
      ' Perform the probe
      Code "G90 G31 Z-" & Probe_Travel & " F" & Probing_Feed_Rate
      While IsMoving()
      Wend
      Z_Probe_Pos = GetVar(2002)
      Code "G0 Z" &Z_Probe_Pos
      While IsMoving()
      Wend
      Call SetOemDRO(802 , Guage_Block_Height)
      Code "G4 P0.500"
      Code "G28"
      While IsMoving()
      Wend
      Message("Tool is now zeroed to Material.")
      ' Restore the original settings
      Code "F" &Initial_Feed_Rate
      Select Case Initial_Abs_Inc
         Case 0
            Code "G90"
         Case 1
            Code "G91"
      End Select
      Select Case Initial_G_State
         Case 0
            Code "G0"
         Case 1
            Code "G1"
      End Select
      Select Case Initial_Spindle_State
         Case True ' Spindle is running so stop it
            If Initial_Spindle_CW_State = true Then
               DoSpinCW()
            ElseIf Initial_Spindle_CCW_State = true Then
               DoSpinCCW()
            End If
      End Select
      ' Restore the original Tool Offset state
         Case True
            DoOEMButton(136)
      End Select
      ' Restore original  Machine Coordinates State
         Case True
            DoOEMButton(179)
      End Select
      Call SetOEMDRO(59, XScale)
      Call SetOEMDRO(60, YScale)
      Call SetOEMDRO(61, ZScale)
   Else
      '  Houston we have a problem
      Answer = MsgBox("Guage Height Block is grounded, check connections and try again", 0, "Oh-oh")
   End If
Else
   Answer = MsgBox("Probe input is not defined in Port and Pins config, configure and try again.", 0, "Oh-oh")
End If
bob78218
