Hello Guest it is November 04, 2026, 10:02:45 AM
Author Topic: Proper directions of X, Y, an Z axis  (Read 37845 times)
Offline Fastest1
  •  920 920
  • Houston, TX
Re: Proper directions of X, Y, an Z axis
« Reply #10 on: March 01, 2014, 10:09:26 AM »
I think I have dyslexia, it is "swap axis" maybe?
« Reply #11 on: March 02, 2014, 04:07:33 PM »
Yes I do have a lathe, but it is a separate machine.  If I were you I would have 2 completely separate profiles, one Machturn for the lathe and the other Machmill.  The axis definitions would be different but you'll have to live with that as the rest of the world uses Z on the vertical axis for milling, including AFAIK CAM progrems to generate milling code.
