Hello Guest it is October 21, 2026, 03:28:48 AM
Author Topic: Combined CNC Engraving Technologies. Spindle + Laser  (Read 29621 times)
« on: February 27, 2014, 08:35:50 AM »
We were able to 3D spindle engrave a height map image in wood and then laser engrave a photo with shades onto it afterwards with the same machine. It took two different photos and Picengrave Pro 4 + Laser to generate the two different Gcode files. Those two files axis movements were then combined into one file so the laser's focal point would follow the spindle engravings profile up and down to stay in focus on the surface of the wood.
http://www.youtube.com/watch?v=rUIrS3Ot1I4
Jeff
Extensivly Re-worked/Re-designed/Modified Servo K2CNC KG-3925 and the Mini Laser Engraver
  •  9,374 9,374
Re: Combined CNC Engraving Technologies. Spindle + Laser
« Reply #1 on: February 27, 2014, 09:35:57 AM »
Brilliant work Jeff - we always knew it was possible but you are the first to have done it - my congratulations.
« Reply #2 on: February 27, 2014, 10:09:59 AM »
Way to go Jeff! That's using the hat rack there. Pushing the envelop .0001 at the time.  :)
« Reply #3 on: February 27, 2014, 10:33:24 AM »
Thanks guys,
I like to have as many options as possible to use my CNC router for. Next!
Jeff
« Reply #4 on: February 27, 2014, 06:03:09 PM »
nice work, nice machine, cool artwork
what size cutter did you finish the piece with?
what would you think the life of the pot will be?
and an interesting way to solve it.
Thanks for the video post. I liked it :D
here is a cool website for some great images you might like.
http://www.legendsofamerica.com/na-nativeamericans.html
« Last Edit: February 27, 2014, 06:05:15 PM by Ya-Nvr-No »
« Reply #5 on: February 27, 2014, 08:27:56 PM »
Thanks for the compliment and the link,
We used a .032" BEM and it was at a .125" total depth. You said pot, I assume your talking about the US Digital MA3 shaft encoder we are rotating with the 4th axis servo motor. They are very reliable. On the first analog modulated laser engraver we built, there's over 1200 hours on it. We only had to replace the 1/8" wide Kevlar reinforced timing belt on it once. Our servo machine in the video has about 250 hours on the encoder since we built it.
Jeff
