Hello Guest it is November 22, 2026, 02:04:00 PM
Author Topic: MACH3 X axis run off?  (Read 10977 times)
« on: February 24, 2014, 06:10:21 PM »
Hi guys,
I'm having a problem. My CNC is running its X axis off of the tool path while its running. I've had this problem before, therefore
I've went and purchased 2 brand new computers and started over. The problem will go away for a short period of time, a few
days or a week, and then will keep occurring. I've been keeping in contact with Lighting CNC Support, and they think that
there's a frequency from the plasma that's interfering with the computers cut. It would be nice to have some help, please answer
ASAP!
Thank you,
Mason.
Re: MACH3 X axis run off?
« Reply #1 on: February 25, 2014, 01:35:03 AM »
Can you clarify what you mean by " running its X axis off of the tool path while its running"
Are you meaning the axis does not follow what is shown on the toolpath view or are you meaning the toolpath view shows the actual movement of the axis when it deviates from the correct path?
« Reply #2 on: February 26, 2014, 03:01:02 PM »
@hood
the X axis running where the toolpath is not showed.
« Reply #3 on: February 26, 2014, 03:04:40 PM »
Can you attach your xml please, also what rev of Mach are you using?
