Hello Guest it is October 05, 2026, 03:45:05 PM
Author Topic: DRO doesnt match gcode move  (Read 12654 times)
« on: February 23, 2014, 05:19:47 PM »
I input as follows
go
x -1.000
y -1.000
z -1.000
And the Dro reads
x -0.9984
y -0.9970
z -0.9997
is there some way to correct for this?
Re: DRO doesnt match gcode move
« Reply #1 on: February 23, 2014, 05:43:07 PM »
Check for backlash and also make sure the steps per are accurate.
Movement is only as accurate as the components that mechanicaly drive it.
« Reply #2 on: February 23, 2014, 05:53:53 PM »
my components are not accurate by any means but i do not understand why if i tell the axis to move one inch the dro doesnt read one inch. I dont have encoders so im not sure why the difference?
« Reply #3 on: February 23, 2014, 06:37:17 PM »
Let me clarify. I do not have an external DRO on the machine I am talking about the computer screen readout in Mach 3. Hope this makes more sense.
« Reply #4 on: February 23, 2014, 07:19:41 PM »
That might just be the resolution of the axis's.
How coarse are the "Steps Per" settings in Motor Tuning ?
Russ
« Reply #5 on: February 23, 2014, 07:27:05 PM »
120 - 122 depending on axis. i am using some old ibm nema 23 motors with delrin ball screws that are pretty aggresive 1.75 inch per turn
« Reply #6 on: February 23, 2014, 07:42:20 PM »
I think you hit the nail on the head! I changed the resolution to 200 and got a lot closer consitantly. when my new motors and lead screws come in i suspect it will get much better!
« Reply #7 on: February 23, 2014, 08:14:53 PM »
Yes, that is quite coarse.
Setting a higher micro-step will help a bit, If your drives have that capability.
Then adjust your "steps per" accordingly of course.
Russ
