Hello Guest it is October 18, 2026, 01:23:10 PM
Author Topic: Galil Error: Could not access DMC Data record  (Read 29837 times)
Offline bubba
  •  80 80
« on: February 21, 2014, 05:59:32 PM »
Hi Guys,
I am trying to get my PC setup to connect to controller.
Galil Optima 1830 is installed
Controller / drives etc is not connected yet.
I have xp pro 32 bit setup with all updates.
Mach 3 installed Demo mode
Galil plug in installed.
Have configured Plugin per PDF included in download
The plugin sees my Galil card
When I launch Mach 3 now in the Status bar I get this message
I have been reading
 Mach3 CNC Controller Software Installation and Configuration Version 3 Manual
I am a bit confused as to what takes priority the PDF DOC in the plug in or the main manual.
Any help would be very helpful!   Getting frustrated.
« Last Edit: February 21, 2014, 06:01:06 PM by bubba »
Offline bubba
  •  80 80
Re: Galil Error: Could not access DMC Data record
« Reply #1 on: February 22, 2014, 03:03:55 PM »
Please Help!
I am still at it with zero results.
Offline bubba
  •  80 80
« Reply #2 on: February 22, 2014, 05:27:44 PM »
Looks like I was using the wrong plugin.
I deleted the plugin and found the .dll in the plugins directory.
Downloaded the Galil-st plugin.
Now when double clicking on the m3p file windows asks what program to open it with. It does not run.
For the hell of it I tried to install the first Plugin sane problem windows ask what program to run it with.
WHAT AM I DOING WRONG !!!!!!!!!!!!!!!!!!
I am not new to doing the CNC software/ controller setup, But getting Mach up and running is kicking my a$$
Offline bubba
  •  80 80
« Reply #3 on: February 22, 2014, 07:02:16 PM »
Fixed.
If it happens to you make sure you have the correct driver.
Offline bubba
  •  80 80
« Reply #4 on: February 22, 2014, 07:03:27 PM »
Try to rename the m3p to .dll did not work for me.
Wiped Mach3 and new install M3p plugin worked perfect!
