Hello Guest it is November 13, 2026, 02:13:50 PM
Author Topic: Relay  (Read 9300 times)
Relay
« on: February 18, 2014, 04:09:09 PM »
Hey guys,
I am having troubles with my geckoG540 board, my relay is not clicking when plugged in.
I changed the relay completely, but im just not 100% sure if the wires are wrong, or what,
If someone could help it would be greatly appreciated.
Re: Relay
« Reply #1 on: February 18, 2014, 05:06:23 PM »
Would need a lot more info before we could even suggest what may be wrong.
For example where have you got the relay connected?
Do you have the correct port and pin numbers assigned?
How are you switching the relay from Mach, ie is it for the spindle or something else?
Offline Fastest1
  •  920 920
  • Houston, TX
Relay
« Reply #2 on: February 18, 2014, 07:41:52 PM »
Are you hooking it up for the first time or did it quit working?
