Hello Guest it is October 22, 2026, 09:00:37 AM
Author Topic: Jittery noisy out of control steppers  (Read 16091 times)
« on: March 08, 2007, 09:14:27 PM »
I am trying to bench run an FET-4 kit from Stepperworld. I start the the software (Mach-2 or 3) then turn on the power supply to the FET-4 and the motors seem to run erratically even with out an NC file loaded. Aren't they supposed to make a nice smooth hum when they run?
If I cycle the power to the FET-4 sometimes they don't always run. Why are they not quiet and in control?
Rob
Re: Jittery noisy out of control steppers
« Reply #1 on: April 08, 2007, 12:17:32 PM »
There is probably noise on the step line or the PPort is 3.3volt instead of 5volt.  Are you using a breakout board or direct to the pc port?
« Reply #2 on: May 20, 2007, 01:19:03 PM »
Turns out the power supply was bad. I have the steppers mounted to the X-Y table now but can't get MACH-3 to move anything. I can get steppers to move if I use VBSTEPDIR4XP.EXE from Stepperworld.
The OS is windows2000, instead of XP. Will this be a problem?
