Hello Guest it is November 13, 2026, 09:47:39 AM
Author Topic: Serial port pins not lit  (Read 10051 times)
« on: February 18, 2014, 06:51:07 AM »
Hi there everybody.
A long story short, In mach3 diagnostics I only have 5 port1 pins lighting up. I have tried every other port address i have and get different results so i am sure its the right address. I know my machine is all working correctly as i have swapped wires around to test the different motors and can jog them as required but i just dont have enough pins?
Is this a PC hardware problem or a software problem? does anybody know please.....close to throwing it in the river :)
Thank you in advance Jim
Re: Serial port pins not lit
« Reply #1 on: February 18, 2014, 10:32:31 AM »
Ignore the current state LEDs, no one seems to know what they are actually representing.
« Reply #2 on: February 18, 2014, 12:09:11 PM »
Ummm so I need to find another reason why only two axis move :(
Sent from my iPhone using Tapatalk
« Reply #3 on: February 18, 2014, 02:33:19 PM »
Test with a scope or a voltmeter direct at the port on the problem pins and see if you are getting outputs.
