Hello Guest it is November 10, 2026, 01:58:37 AM
Author Topic: DXF with Lazycam  (Read 13055 times)
DXF with Lazycam
« on: February 16, 2014, 03:01:31 PM »
Hi!
I have a problem with LazyCam, I enter the DXF file and with it I want to bring out a G code, but we just do their part in G, say only 1/4 forms.
I can not understand where making a mistake, I tried several times but always happens the same thing.
Please can someone to help .
I m attach file to : DXF , LazyCam and TAP ( g code )
Can someone say what is problems ?
Re: DXF with Lazycam
« Reply #1 on: February 16, 2014, 03:33:53 PM »
Not sure what your asking. I notice that you only have 25 lines of code.
Is that your problem?
Do you have a Mach license and also a LC Pro license?
« Last Edit: February 16, 2014, 03:38:04 PM by RICH »
« Reply #2 on: February 16, 2014, 04:39:51 PM »
Problem is because I have only 1/4 G cod  when export G code with LazyCam .
I not have  Mach license , I use free version  .
« Reply #3 on: February 17, 2014, 04:17:53 AM »
LC requires a license to use the advanced features such as offsets  and both Mach and LC limit the number of lines of code you can run.
« Reply #4 on: February 17, 2014, 05:00:27 AM »
You wont say that I need have license Mach3 and LazyCam?
« Reply #5 on: February 17, 2014, 05:07:08 AM »
Don't understand?
« Reply #6 on: February 17, 2014, 05:12:04 AM »
Don't understand?
I need Mach3 and LazyCam with license ?
« Reply #7 on: February 17, 2014, 05:20:42 AM »
LC  limits the posted code to 50 lines and you can not  use the advanced features, like offsetting,  if you do not have a license for it.
Mach demo limits the code to 500 lines.
That is why you are only seeing some of the code when posting code from LC to Mach.
So if you really want to use both purchase licenses. Consider other milling software before purchasing LC since it is Beta forever.
