Hello Guest it is November 13, 2026, 12:38:28 PM
Author Topic: Modbus / MPG help...  (Read 52373 times)
Offline Davek0974
  •  2,606 2,606
Re: Modbus / MPG help...
« Reply #10 on: February 16, 2014, 02:53:26 AM »
I seem to have lost the modify post button, anyway the file in the link above is the macropump.m1s file I used.
It's here...
http://www.cnczone.com/forums/attachments/mach_mill/191332d1373222349-chinese_electronic_handwheel_mach3-macropump.m1s.txt
I presumed they were all the same, but looking inside it maybe it can be fixed if you know what it all means :)
« Last Edit: February 16, 2014, 02:55:22 AM by Davek0974 »
« Reply #11 on: February 16, 2014, 04:34:15 AM »
Neither of these seem  have a ToGo button press so maybe you have a different macropump?
Offline Davek0974
  •  2,606 2,606
« Reply #12 on: February 16, 2014, 05:36:44 AM »
This was the exact file I used, the device came with nothing so I did a google, came up with that link and downloaded it.
« Reply #13 on: February 16, 2014, 05:54:08 AM »
There is nothing in the macropump, that I can see anyway, that is calling the ToGo button (OEM 333), you sure its the ToGo button that is invoked by the Origin button? Dont even see mention of origin in the macropump either, so dont really know which button it is.
Offline Davek0974
  •  2,606 2,606
« Reply #14 on: February 16, 2014, 07:45:30 AM »
Yes, pressing origin just operates the to-go button in mach.
I have emailed the guy but will likely end up returning it through lack of support.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #15 on: February 16, 2014, 08:39:51 AM »
I agree with Hood - there is nothing in that macropump that operates the togo button. In fact all that macropump does is set the jog modes and axis selection. Forgetting buttons for a moment - if your machine jogs when you turn the handwheel it has nothing to do with that macropump so either it's not the one that is actually running or you MUST have either a Brain or a Plugin running.
Why not post a link to what you downlaoded.
Offline Davek0974
  •  2,606 2,606
« Reply #16 on: February 16, 2014, 08:55:36 AM »
That WAS the file I downloaded.
All I did was turn macropump on in config, turn on modbus support, put the file in the plasma macro directory and it started working, but not quite right.
« Reply #17 on: February 16, 2014, 10:36:44 AM »
Can you attach your xml please.
Offline Davek0974
  •  2,606 2,606
« Reply #18 on: February 16, 2014, 03:23:42 PM »
Will do so in the morning, thanks for helping.
Offline Davek0974
  •  2,606 2,606
« Reply #19 on: February 17, 2014, 01:36:16 AM »
Plasma.xml file attached...
