Hello Guest it is November 13, 2026, 11:32:42 AM
Author Topic: set up for two different machines  (Read 12698 times)
« on: March 08, 2007, 05:01:26 AM »
Hello Everybody!
I’m going to build another CNC machine, and I’d like to control both machines by the same Mach 3 software  . My question, is it possibly easily change set up between two machines? The machines have absolutely different controllers, lead screw, purpose and so on. Can I change set up during start up of Mach 3?
Thank you in advance
Vladimir
Re: set up for two different machines
« Reply #1 on: March 08, 2007, 07:52:30 AM »
Vladimir,
    What do you use the two machines for?
Offline rcrabb
  •  146 146
« Reply #2 on: March 08, 2007, 08:46:44 AM »
If your only running one at a time I would think its very easy. Create a setup for each machine. Load the profile (or XML file) for the machine you intend to run. This is done when you open mach and are promted to select a different profile. Each different XML file in the mach directory will be a different profile you can choose. Hope this helps.
Ryan
« Reply #3 on: March 08, 2007, 12:25:49 PM »
Hello Brett .
I already have 4 axis CNC mill machine and I'm going to build 3 axis CNC PCB engraver. Now I'm using CNC mill for PCB engraving, but due to table restrictions and slow speed of axis I'm looking for another solution. I will use one machine at time.
Vladimir
« Last Edit: March 08, 2007, 12:30:39 PM by vladimir059 »
« Reply #4 on: March 08, 2007, 12:28:29 PM »
Hello Ryan. Thank you for reply.
I will try to use different profile during start up procedure.
Thanks again
Vladimir
« Last Edit: March 08, 2007, 12:30:10 PM by vladimir059 »
